Car Repair Chat - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1992 Chevy Blazer Starter problems
Posted at Sun Jan 11, 2009 4:35 pm |
By
challengerboy,
Likes to hang around! |
Give Feedback | Votes: 0 |
Electrical problem
1992 Chevy Blazer 6 cyl Four Wheel Drive Automatic N/A miles
Brand new starter. will not turn ovar, i dissconected the battry and everytime i attempt to put the negative back on the battry it sparks and the starter tries to turn over. the battry is good. whats wrong with this starter? possibly the wire to the fuse box? |
Find a
car repair manual for your Chevy Blazer Repair Question.
Posted at Mon Jan 12, 2009 9:58 am |
By
buddycraigg,
Moderator |
(33) Give Feedback | Votes: 22 |
either the starter is bad,
or you didn't wire something correctly. |
Find a
Posted at Mon Jan 12, 2009 1:43 pm |
By
challengerboy,
everytime the starter clunks, as if it is trying to turn over. The starter is Brand new the wireing i didnt do. could the positave and negative be touching? |
Find a
Posted at Mon Jan 12, 2009 3:19 pm |
By
buddycraigg,
Moderator |
i'm thinking more likely the positive battery cable is touching the small post that energizes the solenoid. |
Find a
Posted at Mon Jan 12, 2009 3:22 pm |
By
challengerboy,
probably its just difficult to get in there |
Find a
Posted at Mon Jan 12, 2009 4:28 pm |
By
buddycraigg,
Moderator |
| challengerboy wrote: | | The same problem occured with the stock, original starter. Replaced it no difference, got the original starter checked at a shop they said it was fine. The spider fuel injector was replaced, along with spark plugs, wires, altenator, belt,and the air intake. The engine did not run when I bought the truck. The injector was out and broken at the time. Put a new charged battery in it and replaced connectors and and wires. When you turn the key the engine will crank for a few rotations, right before it starts it will make a very loud clunk! Then everytime you turn the key it makes the same clunk. If left for several min it will turn over just barely. This problem has been consistent through out replacemtent or cleaning of parts. |
i have to go out on a road call, but i'll take a look when i get back |
Find a
Posted at Mon Jan 12, 2009 9:13 pm |
By
buddycraigg,
Moderator |
I've had a rough night.
I'll check back on this thread as soon as i can. |
Find a
Posted at Wed Jan 14, 2009 4:23 pm |
By
buddycraigg,
Moderator |
maybe i misunderstood what you first said.
is the starter trying to turn over the engine when you connect the battery cables? |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
