Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair2001 Pontiac Sunbird
Auto Repair2002 Honda Civic Baffling...
Auto Repair1997 Other Oldsmobile Mod...
Auto Repair2003 Dodge Neon Engine V...
Auto Repair1995 Ford Explorer Fuel ...
Auto Repair1996 Dodge Neon Whats Wr...
Auto Repair1997 Acura Tl Shifter Wo...
Auto Repair1999 Acura Tl Power Seat...
Auto Repair1994 Acura Integra
Auto Repair1994 Oldsmobile Cutlass ...
Auto Repair1991 Acura Integra Will ...
Auto Repair1990 Acura Integra Stall
Auto Repair1990 Nissan 240sx Starting
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1992 Buick Century Randomly will not start, "backfires
New Watch our new Car Repair Video Series with Ken Lavacot.
Goto page 1, 2, 3  Next
Posted at Fri May 09, 2008 12:03 pm
By tripp78, Likes cars!
Give Feedback | Votes: 0
1992 Buick Century 4 cyl Two Wheel Drive Automatic 138000 miles
Recently my Buick started this problem. Half the time it starts and runs fine, the other half it will not start (after not being used for several hours). When it doesn't start, the first turn of the key sounds normal, but if i continue to try, there is a sort of "backfire" that seems to occur where in the air filter compartment, and there is a puff of white vapor/smoke in the same position.
I do have a check engine light that's been coming on for about 2 months, which I was told was saying that my EGR valve was bad. At the time I was told this at Autozone, they also said it wasn't a serious situation, and at most I would probably have reduced gas mileage until I replaced it.
I'm not sure if the EGR valve could be causing the random ignition failures, and while I wait on my paycheck, I took out the valve and attempted to clean it and oil it with WD40. It didn't fix the problem, so I'm wondering if this could be the whole problem, or if it's not involved, and what the issue might be.
Thanks in advance for any help!
-Steve-
Find a repair manual for your Buick Century Repair Question.
By Advertisment,
Posted at Fri May 09, 2008 12:06 pm
By merlin2021, Certified 2CarPros Master Technician
Reputation: 535.7Reputation: 535.7Reputation: 535.7Reputation: 535.7Reputation: 535.7Reputation: 535.7Reputation: 535.7Reputation: 535.7Reputation: 535.7Reputation: 535.7Reputation: 535.7Reputation: 535.7Reputation: 535.7Reputation: 535.7Reputation: 535.7Reputation: 535.7Reputation: 535.7Reputation: 535.7Reputation: 535.7Reputation: 535.7Reputation: 535.7Reputation: 535.7Reputation: 535.7Reputation: 535.7Reputation: 535.7Reputation: 535.7Reputation: 535.7 (536) Give Feedback | Votes: 45
Cross these two terminals as shown, then turn the key on. Count the flashes, a 22 will flash as 2 flashes then a short pause, then 2 flashes, if more than one code is stored, the pause will be longer. The codes will display three times and end with 12. Write them down and post here. This connector is right under the middle of the dash...
Posted at Fri May 09, 2008 4:13 pm
ok just did that. it seemed to give me two different codes. a 13 and a 32.
thanks again !
Posted at Fri May 09, 2008 5:18 pm
By mastertechtim, Tech level 9
Reputation: 254.2Reputation: 254.2Reputation: 254.2Reputation: 254.2Reputation: 254.2Reputation: 254.2Reputation: 254.2Reputation: 254.2Reputation: 254.2Reputation: 254.2Reputation: 254.2Reputation: 254.2Reputation: 254.2 (254) Give Feedback | Votes: 17
o2 sensor and egr. these are not causing your starting issues. if this has the 4 cylinder engine then most likely the cause is the #1 spark plug wire is bad so rep[lace plugs and plug wires. if the engine is in fact a 3.8l v6 then the problem is probably a faulty coil pack and you can check it by using a ohm meter across the towers of the coils and you will probably find one that has a open in it.
Posted at Fri May 09, 2008 6:29 pm
Ok, I will do that asap. Thanks a ton for the advice. As far as the o2 sensor and EGR issues, I take it I'll just need to replace the sensor, but any advice on diagnosing the EGR code?
Posted at Sat May 10, 2008 2:45 am
Get it running first then we will worry about the egr...32 could also be the MAP sensor voltage is low...
Posted at Tue May 13, 2008 2:04 pm
ok just finished replacing plugs and wires, also went ahead and replaced the o2 sensor.
car started on the first try afterwards, so hopefully that behavior will continue.
edit:
car is still starting. after clearing ECM codes and driving it then getting a check engine light, i'm still getting the 13 and 32 codes.
Posted at Thu May 15, 2008 3:37 pm
well i jinxed myself. it's not starting again, same backfire thing.
any other suggestions?
Posted at Fri May 16, 2008 3:26 am
what ignition system does this have (here are 2 different ) are the coils all one piece or are there 3 seperate coils? if they are all one coil in a block then replace it. you can check for sure by using a ohm meter across the coil towers and i strongly feel you will find a coil out of resistance
Posted at Fri May 16, 2008 12:44 pm
i'm still rather new to this, but as far as i'm understanding, the coils are in a single block. i'm going to check for spark and also test the posts at the coil as you suggested.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
