Free Car Repair Advice by Certified ASE Technicians
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1991 Toyota Cressida replacing timing belt
Posted at Sat May 09, 2009 9:43 pm |
By
falc63,
New to the forum |
Give Feedback | Votes: 0 |
Engine Mechanical problem
1991 Toyota Cressida 6 cyl Two Wheel Drive Automatic 180000 miles
when replacing the timing belt on a 1991 toyota cressida, following the shop manual, what happens when after you remove the spark plugs then hand turn cranksgahft to 0 tdc, the camshafts dont line up with the case marks. It appears that the last belt has left the leftmost cam pulley one tooth behind the right cam pulley. After removing the belt, and as the manual states all the other pulleys, do you then turn the crank again (as it states) and then when reinstalling the cam pulleys(2) dohc., do you then line up the cam matchmarks(built in to the pulleys with the case marks?? Please advise not sure im interpreting the book right..but thats exactly how its stated. |
Find a
car repair manual for your Toyota Cressida Repair Question.
Posted at Sun May 10, 2009 5:13 am |
By
mmprince4000,
Certified 2CarPros Technician |
           (5897) Give Feedback | Votes: 52 |
Set crankshaft timing mark to alignment mark on engine.
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
