Logo Automobile Information Add to Favorites  Automobile InformationLogin  Automobile InformationSign Up
Auto Repair
Auto Repair Home
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair How Does it Work
Auto Repair Automobile Safety Inspection
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Car Repair Manuals
Auto Repair Brake Replacement Guides
Auto Repair Tips Car Owners Should Know
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Definitions
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Recent Repair Topics
Auto Repair1993 Dodge Van Fuse For...
Auto Repair1998 Gmc Jimmy Problem'...
Auto Repair2002 Ford F150 Horn And...
Auto Repair2003 Dodge Ram
Auto Repair2002 Mercedes Benz Ml320...
Auto Repair1996 Chevy Beretta Rebuild
Auto Repair1995 Chevy Lumina Car P...
Auto Repair More Repair Topics...
Car Repair Advice by Professional Automotive Experts
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1991 Toyota Camry no fire to plugs
Posted at Fri Nov 20, 2009 7:32 am
By mater007, Have Donated
Give Feedback | Votes: 0
Computer problem
1991 Toyota Camry 4 cyl Front Wheel Drive Automatic
my car was running fine then just died ,i have had the igniter tested and have changed the entire distributor new coil the works,the coil gets power on both sides but will not fire through the rotor.i have checked all the wires for grounding problems only thing i havent changed is the computer i was told that they hardly ever go out but i dont know...i'm thinking of a burning rag if i can't figure this out HELP please...
Find a car repair manual for your Toyota Camry Repair Question.
Posted at Fri Nov 20, 2009 1:36 pm
By KHLow2008, Certified 2CarPros Technician
Reputation: 5151.9Reputation: 5151.9Reputation: 5151.9Reputation: 5151.9Reputation: 5151.9Reputation: 5151.9Reputation: 5151.9Reputation: 5151.9Reputation: 5151.9Reputation: 5151.9 (5152) Give Feedback | Votes: 69
Hi mater007,
Thank you for the donation.
Did you check if the rotor is turning when cranking the engine? A bad timing belt would not turn the distributor and this would cause a no spark condition.
As you have replaced the distributor, the next thing to check would be the ignition switch and computer.
Test for power supply to the distributor while cranking the engine. A bad ignition switch might provide power to the coil in the ON poaisiton but no power supply when in the START position.
Posted at Fri Nov 20, 2009 3:04 pm
yes the rotor is turning,the timing belt looks fine.i have checked both sides of the coil while the engine was being turned ,the coil stays hot.the low side does not break or flash the test light like it should when the engine is turned
Posted at Fri Nov 20, 2009 3:37 pm
The distributor is not pulsing to fire the ignition coil.
Possible cause would be the ignitor and/or PCM causing the problem.
Did you do the ignitor test yourself?
Is the Check engine light showing?
Did you try to retrieve for trouble codes?
Posted at Fri Nov 20, 2009 6:50 pm
i was told when the car first died that it was probably the igniter so i took it off and took it to a local shop where the tec tested for me.when i removed the igniter i disconnected the battery when i reinstalled the igniter and reconnected the battery the check engine light did not come back on and hasn't yet not even when the key is ON and not in the START position.
Posted at Sat Nov 21, 2009 3:30 am
You would have to check why the CEL is not indicating when ignition switch is turned ON.
Posted at Sat Nov 21, 2009 2:18 pm
i followed the schematic directions as to how to check the CEL when i grounded the wire that comes from the CEL to the ECU to the frame the CEL came on.i then grounded the E1 terminal in the data link directly to the battery the CEL still did not glow..
Posted at Sun Nov 22, 2009 3:04 am
The ECU or its witing is faulty and not grounding the circuit.
Recheck the ECU wire connectors and termnals for contaminations. If none found, you would have to get an ECU to test.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
Test Fuses
More Service Repairs...
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Advertise 2Carpros.com
Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l We're Hiring
Copyright © 1999 - 2010 2CarPros.com - Professional Mechanics Online
