We are the Auto Repair Experts!
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1991 Pontiac Grand Prix Battery Drains Overnight
Posted at Fri Nov 20, 2009 12:30 pm |
By
miklemak,
Have Donated |
(20) Give Feedback | Votes: 0 |
Electrical problem
1991 Pontiac Grand Prix 6 cyl Front Wheel Drive Automatic 95700 miles
I seem to have a parasitic battery drain. A fully charged battery is dead in a day or two. I just bought a new battery and want to solve the problem before the new battery dies. I did a battery drain test on it and found nothing. Here's how I did it. I locked the doors and waited 15 minutes, then disconnected the negative battery terminal and attached an unpowered test light between the negative terminal and the battery and the light glowed brightly. While in the car with the doors closed and key out of the ignition, I removed all of the fuses, one at a time and the light continued to glow. Then, while under the hood with the doors closed and no key in the ignition, I pulled all of the fuses and relays under the hood. I disconnected the Aftermarket CD Changer and throughout all of this, the test light glowed. I disconnected the alternator and just about every electrical device under the hood and the light still glows. All of the accessories operate except for the power antennae and the left turn signal bulb is burned out. In the past 8 months I have replaced the: EGR Valve, IAC, TPS, spark plugs, all filters, brake pads, rotors, calipers, tires, etc, etc, etc.I�m stumped and am hoping you might be able to help; please. |
Find a
car repair manual for your Pontiac Grand Prix Repair Question.
Posted at Sat Nov 21, 2009 6:59 am |
By
mmprince4000,
Certified 2CarPros Technician |
           (5947) Give Feedback | Votes: 52 |
Get yourself a DVOM and repeat the process, set to DC volts at the most sensitive setting (usually 100ths of a volt). Volts will drop until you pull the correct fuse, which will isolate the drain circuit. |
Find a
Posted at Sat Nov 21, 2009 7:03 am |
By
mathiaso,
(292) Give Feedback | Votes: 18 |
Hello miklemak
On late model vehicles with computers and numerous electronic modules, the key-off drain on the battery can range from 20 to 50 milliamps, to as much as 300 to 400 milliamps. that is why the unpower test light will glow as long computers and modules memories are alive.
As a rule, the parasitic drain on most late model vehicles should be less than 50 milliamps one hour after the vehicle has been shut off and left undisturbed
Keep in mind, though, that opening a door, the trunk or turning anything on can wake up various modules and start the timer countdown all over again. So if you want to check the parasitic draw on the battery, leave the hood open.
Current drain can be measured with a digital multimeter (DMM) using the ammeter function.
1. Set the DMM to read milliamps (mA). If the meter is not auto-ranging, select the 100 or 1000 mA scale.
NOTE: the DMM should have a 10 amp fuse in it to protect the meter from possible damage if there is a large current drain on the battery.
2. Plug a battery backup into the cigarette lighter (or attach a backup battery or power supply to the battery cables) to protect KAM while disconnecting the battery cable
3. Disconnect one of the battery cables and connect the DMM test leads to the cable and battery post.
4. Unplug the battery backup and note the current reading on the DMM.
FINDING THE CAUSE OF THE CURRENT DRAIN
If the key-off current reading is above specifications (typically, more than 50 mA one hour after the vehicle has been shut off), the current drain is too high. It's time to start pulling fuses and relays to find the fault.
pull the fuses and relays one at a time until the current reading drops
Avoid pulling the fuses for the PCM or other KAM-sensitive modules until you have checked all of the other circuits.
Once you've found the circuit that is causing the excessive current drain, check the relay, switch, module or other components in the circuit and replace as needed, or we can provide the wiring diagram for further help. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
