Engine Mechanical problem
1991 Other Mercedes Benz Models 6 cyl Two Wheel Drive Automatic 280000 miles
My 1991 mercedes sd turbo deisel has great oil pressure at startup, even at an idle. But after it warms up it barely registers oil pressure at an idle. What are the possible problems and solutions? Thanks for any help!
Find a
repair manual for your Other Mercedes Benz Models.
Posted at Fri May 16, 2008 7:20 pm
By
Advertisment,
Find a
Drop of oil pressure like tins could be caused by either worn engine bearings, faulty pump, oil pick up cracked, oil pump faulty or a pressure relief valve acting up. I would start by getting an oil pressure test done with a master gauge, then you will know exactly what is going on with the pressure.
Mark (mhpautos)
Find a
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
