Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1997 Ford Escort High Idle
Auto Repair1999 Dodge Truck
Auto Repair2007 Toyota Corolla Car...
Auto Repair1999 Plymouth Breeze
Auto Repair1999 Plymouth Breeze Id...
Auto Repair2001 Nissan Sentra Mult...
Auto Repair2004 Chevy Cavalier Rea...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1991 Other Chrysler Models Fuel pressure weirdness
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sat Apr 19, 2008 2:45 am
By Vilpo, New to the forum
Give Feedback | Votes: 0
Engine Mechanical problem
1991 Other Chrysler Models 6 cyl Two Wheel Drive Automatic 230000 miles
Hello, and thank you in advance for your reply.
I was measuring the fuel pressure on my Saratoga and noticed that it was too high for the specification for this car (55 psi without vacuum) on the pressure side of the fuel rail. So i tested if fuel return side was clogged, but it wasn't so i bought a new fuel pressure regulator, thinking this was the problem. It didn't fix it at all. So i went on and tested the pressure on the other side of the fuel rail, before the regulator ofcourse, and it was correct on that point (48 psi without vacuum).
So my question is that how can it be possible that the fuel pressure is higher on the pressure side of the fuel rail than on the exit side?
I suspected that maybe fuel rail is clogged, so i took it out for cleaning and inspection, but i didnt find any clog, when i put compressed air through it.
Fuel pump flow was also tested, and was inside the specification (1,6 pints in 30 seconds).
I've been looking for answer to this on forums but haven't found anything yet.. So thanks in advance for any help.
Edit:
I was testing it again and seems that the problem only exists when the car is running. If i just run the pump engine stopped, the pressure seems the same on both sides of the rail.
Find a car repair manual for your Other Chrysler Models.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
