Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2007 Toyota Corolla Car...
Auto Repair1999 Plymouth Breeze
Auto Repair1999 Plymouth Breeze Id...
Auto Repair2001 Nissan Sentra Mult...
Auto Repair2004 Chevy Cavalier Rea...
Auto Repair2001 Nissan Sentra Over...
Auto Repair1992 Nissan Sentra Head...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1991 Honda CRX engine stutters while driving....
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sat Sep 13, 2008 10:43 am
By cegglestn, Likes cars!
Reputation: 27.8 (28) Give Feedback | Votes: 0
Engine Performance problem
1991 Honda CRX 4 cyl Front Wheel Drive Manual 191000 miles
I have a 91 honda crx hf with the d15b6 1.5l motor. It has been stuttering when driving in all gears especially when the accelerator is in the same position. It starts stuttering than i either step on the gas or let it off a bit and it goes away for awhile than does it again and again. Ive tried everything from timing, fuel filter, plugs, wires, o2sensor. The car doesnt throw any codes on the computer. I have been stuck on this problem for awhile now. Please help.
Thanks,
Chris
cegglestn@yahoo.com
Find a car repair manual for your Honda CRX Repair Question.
Posted at Mon Oct 13, 2008 10:48 am
By KHLow2008, Moderator
Reputation: 178.7Reputation: 178.7Reputation: 178.7Reputation: 178.7Reputation: 178.7Reputation: 178.7Reputation: 178.7Reputation: 178.7Reputation: 178.7 (179) Give Feedback | Votes: 13
Hi Chris,
Does this happen at a praticular engine rpm?
I
Posted at Mon Oct 13, 2008 12:42 pm
No it doesnt it mostly happens when driving steady at a certain speed, example 35mph or 55mph it starts to cut out it seems till I let off the gas or step on the gas.
Posted at Tue Oct 14, 2008 6:00 am
Hi Chris,
The problem seems to be sensitive to throttle movement. Did you check/test the TP sensor?
Posted at Tue Oct 14, 2008 8:07 am
I will have to take it all apart because it has those factory sheer bolts unless there is an easier way Sad
Posted at Tue Oct 14, 2008 8:21 am
Taking it apart would serve no purpose. You can test its voltage at fully closed and open throttle and smooth transition while accelerating.
Posted at Thu Nov 13, 2008 5:57 pm
By Advancrx, New to the forum
same sorta happend to me, but I noticed it was between 2.5 - 3.0 RPM's.
Then all the sudden my car wanted to die when I tried to accelerate from a complete stop.
After talking to a buddy of mine who's been working on honda's for over 14 years noticed right away that fuel pressure regulator was bad, not to mention he found that the TPS was broken off as well,
However he had a temp. fix for me until I could get a new fuel pressure regulator, which was some needle nose vice grips pinching on the fuel line connected to the FPR. just enough to create pressure. Somehow it worked like a charm.
It just may be the FPR thats bad.
Posted at Fri Nov 14, 2008 1:46 pm
Hi Advancrx,
Thank you for the input.
I would say the TPS is more likely to cause the problem then tha FPR but both would cause it.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
