Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2000 Other Fiat Models F...
Auto Repair2001 Mazda B3000 No Pre...
Auto Repair1997 Ford Escort High Idle
Auto Repair1999 Dodge Truck
Auto Repair2007 Toyota Corolla Car...
Auto Repair1999 Plymouth Breeze
Auto Repair1999 Plymouth Breeze Id...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1991 Ford Probe
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Tue Aug 19, 2008 3:27 pm
By adamatrocity, Likes cars!
Give Feedback | Votes: 0
Electrical problem
1991 Ford Probe 6 cyl Front Wheel Drive Automatic 149750 miles
i stuck a screwdriver in my ignition (my father took my keys) and i figured blah it will work but i'm not sure if i messed the ignition switch up cause i still don't have the keys
and i used a paper clip to try to move the pins up but i don't know if there messed up because i just figured that when you stick the key in it moves the pins up and when you push it up it just falls back down (i didn't think of that till after i did the thing with the paper clip)
but if you could tell me if that would mess up the ignition switch or not that would be great
Find a car repair manual for your Ford Probe Repair Question.
Posted at Tue Aug 19, 2008 4:56 pm
By blackop555, Certified 2CarPros Master Technician
Reputation: 106.8Reputation: 106.8Reputation: 106.8Reputation: 106.8Reputation: 106.8 (107) Give Feedback | Votes: 27
you jam it in there or did it just fit right in there?
if you jamed it in there you could have ruined the ignition switch, if it fit right in there its probably still good, if you wanna get your vehicle running
you will have to drill out hte holding pin, then you can start it with a screwdriver.
Posted at Tue Aug 19, 2008 8:23 pm
i really don't want to have to replace the ignition switch
but if it fit right in like it had move to jiggle around then its still good? and the thing with the paper clip didn't mess up the pins?
Posted at Wed Aug 20, 2008 10:56 am
then chances are the switch is in good shape, since you didnt jam it or ream on it. it is spring loaded so pusing on them wont help.
Posted at Wed Aug 20, 2008 6:53 pm
okay so your saying that since i didn't jam the screwdriver in its fine about that?
and that since the pins are spring loaded then that's fine as well?
by the way thanks for the help i appreciate it
Posted at Thu Aug 21, 2008 5:50 am
is all safe if there was no prying or jaming involved, when you push a key it the prongs go up and then back down into the spot its supposed to be, its the same principle of picking a lock only harder because of two sides.
Posted at Thu Aug 21, 2008 9:48 am
welll we tried two screwdrivers 1 big one that barely fit in the hole and i trie dto turn the switch and nothing
so i pulled it out
then i small on that had alot of room to jiggle around and tried to turn it it didn't work so i pulled it out
i tried using a paper clip to pick the pins that didn't work cause i couldn't get the last pin to come up so i pulled that out and i used some long pointy steel thing and tried pushing pins up but it couldn't even fit in there so i didn't force it
i didn't force any of the objects in or out
the only thing i applied a small amount of pressure to is when i was trying to turn it but when i seen that it wasn'tgonig to turn i pulled it out
so everything's fine?
Posted at Fri Aug 22, 2008 6:04 am
by what you described to me, sounds like you did no harm.
Posted at Fri Aug 22, 2008 7:21 am
alrite well thank you
my dad's bringing me the keys in about an hour so i'll tell you everything works or not and if it does then i'll definitely give a donation
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
