Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Cooling problem
1991 Ford Probe 4 cyl Front Wheel Drive Automatic 144000 miles
my engine has been overheating the last couple of times i have driven the car. the coolant tank is holding coolant and i just put in some oil yesterday.
first thing to do is change the thermostat cheap and easy to do and check the hoses make sure their not collapsed.
after those are done start engine let it get hot, squeeze upper hose then release
do you feel pressure build then coolant rush by when you release your hand if not the water pump may not be functioning properly.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
