Welcome to our question and answer forum. We answer over
6,000 free and donated auto repair questions every
month. All you have to do to ask a question is to signup
to our forum.
Asking a question is free of charge and your question
will be answered by one of our non-certified forum users
for free. You can however elect to donate to make sure
your question gets an guaranteed and professional answer
by one of our many 2carpros certified repair
technicians.
Questions
with donations are answered as promptly as possible.
Due to the nature of car repair problems, some take
longer to solve than others. We are confident that you
will be better informed regarding your problem and will
have an good idea of what direction your repair needs to
go after we have answered it. If you have donated and
were unsatisfied with our effort we will gladly return
your donation. We help thousands of people every month
and want to help you too. Sometimes it requires some
dialog between our technicians and you to get to the
bottom of your problem. 100% of the
donation is awarded to the technicians helping you.
Electrical problem
1991 Ford Mustang V8 Two Wheel Drive Manual 100000 miles
My car doesn't want to start today. Car has a new starter and solenoid, newer coil and new battery. I can get the car running by jumping the solenoid with a screwdriver, but when i try to start it in the ignition... Nothing. the starter won't even turn. Do ignitions fail without warning? don't know much about electrical in a vehicle.
Have helper hold key at start position, you check for power at the starter relay terminal red and lite blue wire -do you have it -if not check at the neutral safety switch white and pink wire -you got power there replace the NSS-no power there replace the ignition switch. Power at the starter relay red and lite blue replace the starter relay
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
