Free Auto Repair Advice by Professional Mechanics
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1991 Ford Escort car wont start.
Posted at Thu Nov 05, 2009 8:46 am |
By
larry turner,
New to the forum |
Give Feedback | Votes: 0 |
Computer problem
1991 Ford Escort 4 cyl Two Wheel Drive Automatic 147452 miles
tire blew out ran off road on hill, ground wet ran over lot of plants, car started up 2x, when got a tow down car didnt start up fuelout light showed up. got new battery and starter, still wont start, could it be autinator or a computer part needs to be replace. |
Find a
car repair manual for your Ford Escort Repair Question.
Posted at Thu Nov 05, 2009 8:51 am |
By
rasmataz,
Certified 2CarPros Master Technician |
                             (14908) Give Feedback | Votes: 349 |
If its cranking over and will not start:
disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Won't crank over/nothing:
Could be the starter, starter relay, park/neutral switch and ignition switch |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
