Free Auto Repair Advice by Professional Mechanics
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1991 Ford Escort Engine won't turnover
Posted at Tue Oct 20, 2009 1:54 pm |
By
j2lester,
New to the forum |
Give Feedback | Votes: 0 |
Electrical problem
1991 Ford Escort 4 cyl Two Wheel Drive Manual
Car was experiencing jerky acceleration so I performed compression tests on the cylinders per manual instructions. Only disconnected spark plug wires and ECS plug so engine wouldn't start while checking compression. Compresession checked ok and engine was cranking fine. Came back later to try other test, but engine didn't crank, dash lights on, headlights worked etc. Assumed battery had gone dead during compression checks so attempted to jump start car. No joy. Installed new battery, no joy. Jump started WITH new battery no joy. Haven't attempted to start it by pushing it and engageing clutch for lack of assistance. There is no sound when the key is turned to start, dashboard lights all on, a few relay clicks here and there, but no starter engagement or cranking. nothing. Rechecked electrical connections multiple times, all connections are in place. |
Find a
car repair manual for your Ford Escort Repair Question.
Posted at Sat Nov 07, 2009 10:43 pm |
By
Jolena2370,
Likes to hang around! |
(19) Give Feedback | Votes: 0 |
Have you checked you starter solenoid? that would be where I would start. then I would check the starter. If you have any questions please feel free to e-mail. Thank you |
Find a
Posted at Thu Dec 03, 2009 1:03 pm |
By
j2lester,
New to the forum |
| Jolena2370 wrote: | | Have you checked you starter solenoid? that would be where I would start. then I would check the starter. If you have any questions please feel free to e-mail. Thank you |
This engine doesn't have a starter solenoid. It is a solid state electronic design consisting of an ignition module, coil, distributor and spark plugs. |
Find a
Posted at Thu Dec 03, 2009 8:19 pm |
By
Jolena2370,
Please describe to me how the starter works without a starter solenoid. I have not yet seen one like that. I had a 92 and there was still a solenoid. If you need me to I will take a picture of one for you. I am one hundred percent that there is a starter solenoid on your car is that a 1.8/1.9L? Please feel free to E-mail me back thank you! |
Find a
Posted at Mon Dec 07, 2009 10:47 am |
By
Steve LV,
(7) Give Feedback | Votes: 0 |
"Some" starters have the solenoid built in to the starter housing... So you have to replace the whole starter whether it's the solenoid or the armature that's bad...
If it has a remote solenoid, it should be easy to find... |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
