Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1994 Mercury Sable Wher...
Auto Repair2004 Chevy Silverado Ra...
Auto Repair1996 Chevy Astro All El...
Auto Repair2001 Nissan Pathfinder ...
Auto Repair1991 Honda Accord Rotors
Auto Repair1993 Mercedes Benz 300sd...
Auto Repair2001 Mazda B3000 No Pre...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1991 Ford Aerostar
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sat Aug 16, 2008 4:33 pm
By barryh, Have Donated
Give Feedback | Votes: 0
Electrical problem
1991 Ford Aerostar 6 cyl All Wheel Drive Automatic 190,00 miles
my power windows won't work,I direct wired from the battery to the window motor,it worked next I direct wired to the window switch and engaged to down position,motor worked,I don't have any voltage to the driver door switch,I checked voltage at the fuse and only get 4 volts.Is there another voltage regulator or relay for these windows?. The passenger window will not work on it's own independent switch.My wife says both windows stopped working at the same time(it's her car).Any power you can direct on the subject would be greatly appreciated, thanks Barry.
Find a car repair manual for your Ford Aerostar Repair Question.
Posted at Sat Aug 16, 2008 5:03 pm
By merlin2021, Certified 2CarPros Master Technician
Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1 (633) Give Feedback | Votes: 51
POWER WINDOWS -1991 Ford Aerostar
Page 1 of 1
AEROSTAR DIAGNOSIS
Both Windows Inoperative
Check circuit breaker No. 14 in fuse panel. If circuit breaker opens when either window is operated, check window motor current draw. See WINDOW MOTOR TEST in this article. Check for voltage on Light Blue/Black wire at master window switch. Check for continuity between Black wire at master control switch and ground.
Left Window Inoperative
Check for voltage on Light Blue/Black wire at master control switch. Check master control switch operation. Check for open in Yellow wire and White/Black wire between master control switch and left window motor. Using 12-volt source, check left window motor operation.
Right Window Inoperative (From Master Control Switch)
Right Window Inoperative (From Right Control Switch)
Check for open in Light Blue/Black wire between fuse panel and right control switch. Check right control switch operation.
© 2007 Mitchell Repair Information Co., LLC.
http://www.ondemand5.com/mric/common/asp/printart.aspx
8/16/2008
The other problem you might have is broken wires in the conduit between the door and the cab.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
