Auto Repair Help by Professional Mechanics
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1991 Dodge Shadow A/C blowing hot air, only blowing through
Posted at Tue Aug 18, 2009 12:44 pm |
By
nls,
Have Donated |
Give Feedback | Votes: 0 |
Air Conditioning problem
1991 Dodge Shadow 4 cyl Two Wheel Drive Automatic 165000 miles
About 2 months ago the AC started blowing lukewarm then hot air
Then a few weeks later started blowing only through the top vents at the windshield. Can't get other vents to work.
I got a recharge and retrofit kit thinking the refrigerant was low BUT:
1. I can't figure out which is the low pressure hose on this car (I got a eautorepair.net subscription and they don't have a diagram of this car's AC layout)
2. It looks like the the receiver/dryer canister is on the passenger side above the wheel well, but I can't see any glass window to check the refrigerant.
3. I tried pressing one of the schrader valves on the compressor and something hissed out (cold)
4. There is a plate on the face of the clutch pulley that's loose and rattles when the compressor runs.
I'm unemployed (and live in Arizona 103 today), so if I can do this repair myself it would be great. |
Find a
car repair manual for your Dodge Shadow Repair Question.
Posted at Tue Aug 18, 2009 1:04 pm |
By
Docfixit,
Certified 2CarPros Master Technician |
         (4955) Give Feedback | Votes: 81 |
Hi
The low side fill port is on compressor.
As for air flow that is controled via vacuum and actuators possible vacuum line off or master select switch faulty.
Clutch could be issue down the road. Do you have gagues? do you know what pressures should be?
Low side 35psi High 200psi are you using R12 or going to try 134A?
Thanks for donate
see diagram of vacuum |
Find a
Posted at Tue Aug 18, 2009 2:48 pm |
By
nls,
Have Donated |
thanks for your response.
I'm switching to 134 refrigerant. I bought a converter kit.I can't buy the other stuff without a mechanic's license.
There are multiple schrader valves on the compressor. How do I know which one to connect to?
I have a gague that came with the conversion kit. |
Find a
Posted at Wed Aug 19, 2009 5:20 am |
By
Docfixit,
Be on compressor head largest diameter line attached to that port. line will go to evap other is high and goes to condensor. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
