Welcome to our question and answer forum where over 6,000
free auto repair questions are answered every month,
after you have completed our free signup you will able
to ask a question and receive an answer from one of our
many forum members.
If you elect to donate any small amount of money we will
assign one of our 2CarPros Certified Repair
Technicians to answer your question. Questions
with donations are answered promptly and 100% of the
donation is awarded to the technician helping you.
Engine Performance problem
1991 Chevy S-10 4 cyl Two Wheel Drive Manual
The engine idle will often race at a very high idle even after the engine is warm. It idles fast enough to maintain 40 mph in third gear without touching the accelerator. This engine only has about 30,000 miles on it. We have checked the cable and throttle and nothing is sticking. We also recently changed the temperate sensor at the water pump.
Any Ideas?
Check for vacuum leaks with carb cleaner, spray around carefully, if the engine changes, you have found a leak, if nothing it could be a sticky Idle Air Control Motor (IAC)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
