Free Auto Repair Advice by Professional Mechanics
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1991 Chevy S-10 My car wont run
Posted at Sat Nov 07, 2009 11:53 am |
By
Schmichael325,
New to the forum |
Give Feedback | Votes: 0 |
Engine Mechanical problem
1991 Chevy S-10 6 cyl Four Wheel Drive Automatic 130000 miles
I have a 1991 Chevy s10 blazer. I was driving it up a hill, so I gave it gas. The car down shifted and revved up. At the top of the hill the when the car shifted back up, it stalled like it was out of gas, but it wasn't. Now the car will start but will not idle. You can rev it up by pressing the gas but it will stall out if you hold the pedal down. The only way to keep it running is to tap the pedal. The check engine light doesn't come on. When i unpluged the MAP sensor it the engine runs, but not as good as it should. I have cleaned the EGR valve, checked the PCV valve, changed the EGR solenoid, and the MAP sensor. I am out of ideas and could use some help. |
Find a
car repair manual for your Chevy S-10 Repair Question.
Posted at Thu Nov 12, 2009 6:20 am |
By
Jacobandnickolas,
Certified 2CarPros Master Technician |
                               (15771) Give Feedback | Votes: 122 |
Have you checked for vacuum leaks? Fuel pump pressure? Temp sensor? |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
