Posted at Thu May 01, 2008 7:26 am |
By
ethannevansmom,
Have Donated |
Give Feedback | Votes: 0 |
1991 Buick Century 6 cyl
Alright, I am needing help, I have a buick century that is just not wanting to start, while driving it all the lights on the dashboard came on and i couldn't get the gas going, so after having it towed home, we realized that there was no gas getting to the engine, so, we replaced the fuel pump, fuel filter, crank sensor, ignition/control module, relay switch, coil packs, even the injectors...no luck, so i put it in the shop they said a bad module so we replaced it AGAIN, and nope, still not running...so then they said bad crank sensor.....does this make sense to anyone????? Thank you all so much!!!
| Find a
repair manual for your Buick Century Repair Question. |
By
Advertisment,
| Find a
Posted at Thu May 01, 2008 9:21 am |
By
Buzzsaw,
Tech level 7 |
          (214) Give Feedback | Votes: 11 |
| ethannevansmom wrote: | 1991 Buick Century 6 cyl
Alright, I am needing help, I have a buick century that is just not wanting to start, while driving it all the lights on the dashboard came on and i couldn't get the gas going, so after having it towed home, we realized that there was no gas getting to the engine, so, we replaced the fuel pump, fuel filter, crank sensor, ignition/control module, relay switch, coil packs, even the injectors...no luck, so i put it in the shop they said a bad module so we replaced it AGAIN, and nope, still not running...so then they said bad crank sensor.....does this make sense to anyone????? Thank you all so much!!! |
was it still running when all the lights came on or did it just die and then the lights came on?
| Find a
Posted at Thu May 01, 2008 7:26 pm |
By
ethannevansmom,
Have Donated |
| Buzzsaw wrote: | | ethannevansmom wrote: | 1991 Buick Century 6 cyl
was it still running when all the lights came on or did it just die and then the lights came on? |
It was running when all the lights came on, i just coasted it over to the side of the road!
| Find a
Posted at Fri May 02, 2008 9:13 am |
By
Buzzsaw,
Tech level 7 |
| ethannevansmom wrote: | | Buzzsaw wrote: | | ethannevansmom wrote: | 1991 Buick Century 6 cyl
It was running when all the lights came on, i just coasted it over to the side of the road! |
do you have the car now or is it still at your shop?
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
