Transmission problem
1991 BMW 525 6 cyl Wheel Drive Type unknown Automatic 190624 miles
i HAD A TRANSMISSSION LEAK THE MAN PUT A SEAL AROUNG THE LARGE PAN. BUT IT IS STILL LEAKING THE MAN SAID THAT IT MIGHT BE THE TRANSMISSION SHIFTER SELECTOR SEAL HE SHOWED IT TO ME. dO YOU THISNK THAT WILL STOP MY LEAKAGE. IT LEAKS WHEN i DRIVES THE CAR WHAT DO YOU THINK WRONG WITH THE CAR. HOW MUCH DO THESE PROCEDURE COST IS IT HIGH JUST TO PUT THAT LITTLE RING AROUND THAT SEAL.
According to the flat rate labor guide, the time allotted for this repair is 4 flat rate units which is about a half an hour, plus the cost of the seal.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins.Click
here to find out more.
