Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Performance problem
1991 Acura Integra 4 cyl Two Wheel Drive Automatic 164000 miles
While driving with Drive gear, if I step on gas and speed reaching 45-50 mph; then the S3 gear flashing nonstop, at the point the overdrive S4 will not shift. The speedometer go back to 0 mph and stay there even I step on gas pedal; also the mile travel counter is stop!
What is the problem? What part need to be replaced?
Lately the check engine light is on! Is this the proble of the Oxygen sensor?
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
