Auto Repair Chat - Ask a Question, Get a FREE Answer.
Go Back
1990 Toyota Pickup Loud banging noise
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Mon Sep 01, 2008 7:09 pm |
By
allervite,
Have Donated |
Give Feedback | Votes: 0 |
Engine Mechanical problem
1990 Toyota Pickup 4 cyl Four Wheel Drive Manual 178000 miles
My truck always made a slight knocking noise that got louder as i let off the accelerator. I always assumed it was a badly adjusted valve. Recently, while climbing it got a lot louder. I pulled the valve cover off expecting to find a loose valve stem nut. They were all still tight. I drove another 15 miles when I heard a huge bang and the wheels locked up for a second. The knocking noise was now gone. I started heading for home when the car did the same thing a few more times. I pulled over and called for a tow truck. I tore the engine apart and cannot find any damage. The top end seems find and the rods are not broken the bearings on the cam shaft also seem ok. When I crank the engine by hand the pistons move freely with no strange noises. Any ideas?
| Find a
car repair manual for your Toyota Pickup Repair Question. |
Posted at Tue Sep 02, 2008 2:00 am |
By
mhpautos,
Certified 2CarPros Master Technician |
                         (517) Give Feedback | Votes: 11 |
Hi there,
Thank you for the donation.
Reading your question, i find one comment interesting, you say the wheels locked up for a second, if this was the case and the engine was still running i feel the problem is not in the engine, as you have already stripped the engine further testing and diagnosis is not possible, but if as you have, we have to think long and hard about what is going on. You say there is no indication as to a problem in the engine, with the sort of noise you were describing i feel that it would be fairly obvious if there was something wrong. I feel that with the knocking and the lock up, i would be interested in what the diff oil looks like, i would drain that and check for metal fragments first. have a look here and report your findings. Also as you have the engine down, pull the pistons and make sure that you don't have a cracked skirt as this will cause a knocking noise and drop off the main bearing caps and check that all is well there as well.
Mark (mhpautos)
| Find a
Posted at Tue Sep 02, 2008 8:48 pm |
By
allervite,
Have Donated |
I will check the differential oil and and pull the pistons and get back to you.
When I crank the engine by hand I feel some resistance at certain points in the stroke but no grating, grinding or clunking. I did notice some very deep grooves worn by the timing chain.
I cannot believe such a violent noise has not left any obvious signs. After the first bang, I coasted the truck down a long hill in third gear and it made no noise. When I got to the flat and started to accelerate it happened again but the noise stopped as soon as I let off the accelerator.
When I got home and the truck was loaded off the tow truck, I started the truck and nosed it into the garage. It sounded like I had rocks in the crank case the whole time until I shut it off. I tore it down before trying to diagnose the noise because the noise was so violently loud I expected pieces to literally fall out of the engine when I tore it down.
| Find a
Posted at Thu Nov 13, 2008 11:30 am |
By
allervite,
Have Donated |
| mhpautos wrote: | Hi there,
Just curious if you have found the problem yet?
Mark (mhpautos) |
The loud bang was the timing chain guide being ripped off and hanging up on its way to the oil pan. The banging noise after that, sounding like a broken rod, was the guides bouncing around in the engine. The problem is the guides are plastic,but that is also the good thing in that the palstic did not cause any extra damage bouncing around inside there. A bit of research showed this to be a fairly common problem with Toyota truckes of this era. As a matter of fact, there are many after market steel versions of these guides to remedy the problem.
Also, without the guides, the chain wore a hole through my timing cover.
Hope this helps future posters.
Mike
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
