Auto Repair Talk - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1990 Plymouth Acclaim Cranks but won't start
Posted at Thu Jul 02, 2009 12:08 pm |
By
kevin_r,
Likes to hang around! |
(10) Give Feedback | Votes: 0 |
Electrical problem
1990 Plymouth Acclaim 4 cyl Two Wheel Drive Automatic 103000 miles
Have this problem - driving down the road, my car will sputter out and stall - happens mostly at stop lights, but sometimes while driving as well. I thought I had determined it was not a fuel problem by spraying some fuel into the EFI by the air filter.
I changed plugs, wires, distributor cap, and rotor - still same problem. Testing for spark by removing cable from distributor cap and grounding it against chassis - testing spark directly from the coil, I get a spark, but it doesn't seem like the typical vibrant blue that i've seen, more orange.
I'm pretty poor, so I don't have the means to take it to a shop - I have no problem changing parts myself, I just wonder what exactly it could be without replacing my whole electrical system. If it's even the electrical system. |
Find a
car repair manual for your Plymouth Acclaim Repair Question.
Posted at Thu Jul 02, 2009 12:22 pm |
By
Docfixit,
Certified 2CarPros Master Technician |
                                 (3401) Give Feedback | Votes: 61 |
Spark must be blue/white coil is most likely weak |
Find a
Posted at Thu Jul 02, 2009 1:49 pm |
By
kevin_r,
Replaced the coil - still an orange spark ... very weird. What else was weird - first attempt to start off of a "jump start" worked - but charge does not make sense to me as with a meter, the battery reads 13v turned off, and almost 14v running. |
Find a
Posted at Thu Jul 02, 2009 1:56 pm |
By
Docfixit,
Alternator output should be 14.5 to 15.1 but if batt with 13V static output seem good. Can't figure orange spark. Check battery ground and check voltage to I think Red or orange wire on coli. |
Find a
Posted at Thu Jul 02, 2009 1:59 pm |
By
kevin_r,
coil voltage seems to fluctuate between 1.5 and 1.7v, not sure what nominal should be though |
Find a
Posted at Sat Jul 04, 2009 7:51 am |
By
Docfixit,
Need system voltage to coil something wrong with that circuit. Try running a jumper wire to coil see if it lights. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
