1990 Other Plymouth Models My 90 Plymouth Laser won't start
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Noises problem
1990 Other Plymouth Laser 4 cyl Front Wheel Drive Manual 133000 miles
I am not positive why but when I try to start the car it seems to be flooded. I believe it has to do with a noise that sounds like a chirping sound when I turn the key to the run position. I can get it to start if I put the throttle to the floor but it runs very rough and smells very bad. I believe it might be the throttle positioning sensor but I do not know for sure and I was hoping for some advice so I don't have to make trips back and forth to the auto parts store.
You may be right. It could be the TPS; however, it could be a few other things. Have the computer scanned for codes first. Most nationally recognized auto parts stores will scan it for free.
well I ended up taking to have it tested and the TPS did need to be changed but I have also found out that the computer is bad and I have sent it to a repair place in FL and I am waiting for that to come back. Also they said I need to change the ISC because it looks like it nearly burned up the computerto an unrepairable state.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
