Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1985 Nissan Truck Help ...
Auto Repair1986 Ford F350 Fuel Sup...
Auto Repair1986 Toyota Camry Brake...
Auto Repair2005 Chrysler Pt Cruiser...
Auto Repair2005 Chevy Cavalier Fue...
Auto Repair2003 Chevy Silverado He...
Auto Repair1997 Hyundai Tiburon
Auto Repair More Repair Topics...
Site Advertising
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1990 Other Isuzu Models dash warning lights came on
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sat Jul 26, 2008 9:27 pm
By QuantumRift, New to the forum
Give Feedback | Votes: 0
Electrical problem
1990 Other Isuzu Models 4 cyl Four Wheel Drive Manual 184000 miles
Thurs morning truck started OK. At lunch battery was dead. Suspected I left lights on, but did not. Jumped car and it ran OK rest of day. Near home, the heater/A/C blower (fan) ceased to work, A/C quit, and the dashboard warning lamps all came on. I got home, and shut it off. After a few minutes I tried to start it. It ran for about 4 seconds and died. Tried that a couple of times, and it would not run. I opened hood and smelled burnt electrical components and determined alternator was at fault (I replaced Isuzu OEM alternator 4 yrs ago with remanufactured unit). Battery is a 3 month old DIE HARD GOLD. Anyways I pulled the alternator and replaced it with a new (remanufacured one from Checkers..brand = Autolite). I put the battery on a 6/2 am charger, and went to Checkers and got a new alternator (which I installed today). I then cranked the engine, it started and the BRAKE, LOW FUEL (truck is not low on fuel as it has half a tank of fuel) and BATTERY warning lamps are illumniated on dash (still). The "Check Engine" was NOT lit. I went to Sears, then Checkers (to get two diagnostics) and the battery was verified as good (and charged) and new alternator was verified as good (charging 13.7V, diodes and so forth all check out fine). I pulled the battery cables off again to see if that would clear issue, but no go. There is no short or drain on any circuit (tested this as well before I quit for the night). The heater/AC blower is stilll out, and when the A/C button is engaged, the A/C clutch does not engage on the A/C compressor pully. I thoroughly checked both fuse blocks for blown fuses relating to A/C and blower motor and the fuses all check good.
What is causing this problem?
Find a car repair manual for your Isuzu Truck Repair Question.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
