Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1994 Other Ford Models B...
Auto Repair2001 Subaru Outback Val...
Auto Repair1990 Ford Thunderbird
Auto Repair2002 Other Nissan Models
Auto Repair1985 Nissan Truck Help ...
Auto Repair1986 Ford F350 Fuel Sup...
Auto Repair1986 Toyota Camry Brake...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1990 Mazda Miata converted system R12 to R134
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Tue Aug 26, 2008 2:05 pm
By warrenJ, Have Donated
Give Feedback | Votes: 0
Air Conditioning problem
1990 Mazda Miata 4 cyl Two Wheel Drive Manual 136000 miles
my compressor cluth locked up...so in replacing the compressor and clutch as they are one pc we converted to R134 since the compressor came loaded with 134....found hole in evaporator and replaced it along with Receiver dryer and expansion valvle.....does not cool below 52 and seems to go between 52 and 56 depending on ambient temp. ANy ideas as to what could be wrong...I was told the conversion would be slightly less effecient but not really noticeable ...but now we are all scratching our heads as to how to resolve the problem
Find a car repair manual for your Mazda Miata Repair Question.
Posted at Wed Aug 27, 2008 12:47 pm
By merlin2021, Certified 2CarPros Master Technician
Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1 (633) Give Feedback | Votes: 51
You changed ALL the oil? This uses PAG oil, not compatable with R12...and do not use the same amount of R134 as R12, use less.
Posted at Wed Aug 27, 2008 6:54 pm
Yes the system was vacumed down and then filled with appropriate oil and freon. I will have to double check the amount of Freon used..I know the pressure were reading right the first time....We vacumed out the system again and refilled it.....I have to double check but one of the techs mentioned he thought the pressure readings were not where they were supposed to be....We even changed out the compressor under warranty to see if that would fix the problem but it is cooling even worse than before
Posted at Thu Aug 28, 2008 9:54 am
Try replacing the reciever/drier, and the expansion valve. Low side sould be 30-40 and high 150-200 on an 80 degree day.
Posted at Fri Aug 29, 2008 11:26 am
Yes all components except the condenser have all be replaced and the compressor twice......we are thinking of vacuming down the system and trying R12 as that is what the system was designed for....any othe ideas as to why the R134 wont work .. Do you know anything about the product Freeze 12 they tought it as a better replacement for R12 than R134.....I assumed it was a marketing gimmick and really R134 in disguise....what are your thoughts
Posted at Sat Aug 30, 2008 12:43 am
R12 is not sold in the USA anymore...freeze12 is not R12. Expansion valve in the evap core may need to be replaced. Call Mazda to see if it needs a different valve than the stock valve. Do you have the h & L side readings?
http://www.teamchicago.com/imperial/imp-ac.htm
Read about conversion here....and the Govt website
http://www.epa.gov/ozone/title6/609/index.html
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
