Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1994 Chevy S-10 Runs Ro...
Auto Repair1997 Ford Thunderbird B...
Auto Repair1999 Ford Taurus Engine...
Auto Repair1997 Ford Thunderbird M...
Auto Repair1989 Ford F150 89 Ford ...
Auto Repair1993 Ford Crown Victoria...
Auto Repair2001 Chevy Tahoe Hard T...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1990 Lincoln Continental Battery Drains in a few hours
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Goto page 1, 2  Next
Posted at Mon Sep 15, 2008 11:17 am
By popadoc, Likes cars!
Give Feedback | Votes: 0
Electrical problem
1990 Lincoln Continental 6 cyl Front Wheel Drive Automatic 153k miles
As the title says the new battery gets drained in matter of just a few hours. Alternator is putting around 14.0 to the battery running. Have done the test light test(remove negative cable from battery, hook one end of test light to it and touch the negative terminal with the other) got a big bright light there. Removed fuses 1 by 1 and never had the light go off. Done the night time thing making sure no lights where on or the auto lamp thing wasn't screwing up. Any suggestions??
Thanks
Find a car repair manual for your Lincoln Continental Repair Question.
Posted at Mon Sep 15, 2008 1:58 pm
By merlin2021, Certified 2CarPros Master Technician
Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1 (633) Give Feedback | Votes: 51
Get an analog voltmeter remove the negative battery cable, attach the Black lead to the battery post, Red lead to cable end, then pull fuses one at a time, make sure there are no accessories or lights in the on position, Key off! Close the door after each fuse and check meter, when you pull the fuse for the bad curcuit, the meter will drop to 1 volt or so. Check all fuses, even under the hood. If meter does not drop, remove the battery connection from the alternator, if it drops now, the diodes are bad in the alternator. Put the fuse back in were it goes as you go so you don't forget which fuse goes were!
Posted at Wed Sep 17, 2008 1:00 am
Thanks for the reply. I done all this as you said but nothing happened. I done the fuses 1 by 1 and the fuses in the power distribution box under the hood, removed the battery hook up to the alternator but the voltage never changed. I'm stumped and don't know where to look next. Thanks
Posted at Thu Sep 18, 2008 12:52 pm
You did have the doors closed? ALL switches in the off position? The brake lights are out?
Posted at Thu Sep 18, 2008 3:07 pm
Yes, I had someone in the car with the doors closed pulling fuses and all switches was off.
Posted at Fri Sep 19, 2008 11:31 am
Where all accessories working OK? Any fuses blown latley? And, try unpluging sensors one at a time and check the gauge, 02 especially. If check engine light was on pull the codes, may point to the problem.
Posted at Thu Oct 02, 2008 12:20 pm
Well all the accessories is off. I have unplugged all the sensors I can get to, and unplugged all the other things I can get to. Only thing blown on the car is headlight bulbs, hi and lo on 1 side and low beam on the other side but when I use the headlight flashe but bulbs work. I have re-done the fuse pulling and the only thing that makes the meter lose around 1 volt is the fuse under the hood in the power distribution box for the fuse box????. Don't have access to a scanner so couldn't perform that. I'm a little confused when it comes to under the dash, I'm not to sure if theres anything there that has to do with the air bag system, I don't have a good schematic so I only unplugged the blower motor.
Posted at Thu Oct 02, 2008 12:29 pm
With alternator disconnected it still drains?
Posted at Thu Oct 02, 2008 1:12 pm
When I disconnect the alt. the meter never changes. Maybe I'm doing something wrong with the meter.
Posted at Thu Oct 02, 2008 1:55 pm
Explain how you have it attached?
Goto page 1, 2  Next
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
