Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1986 Ford F350 Fuel Sup...
Auto Repair1986 Toyota Camry Brake...
Auto Repair2005 Chrysler Pt Cruiser...
Auto Repair2005 Chevy Cavalier Fue...
Auto Repair2003 Chevy Silverado He...
Auto Repair1997 Hyundai Tiburon
Auto Repair1993 Other Mazda Models ...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1990 Geo Storm Removing Fuel Injectors
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sun Aug 31, 2008 7:17 am
By RNeathery, Likes cars!
Give Feedback | Votes: 0
Engine Performance problem
1990 Geo Storm 4 cyl Front Wheel Drive Automatic 136,00 miles
Do I have to remove the upper part of the intake manifold to remove and reseal the 4 fuel injectors?
Find a car repair manual for your Geo Storm Repair Question.
Posted at Sun Aug 31, 2008 7:35 am
By merlin2021, Certified 2CarPros Master Technician
Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1 (633) Give Feedback | Votes: 51
FUEL RAIL & INJECTORS (PFI) R & I REMOVAL 1. Clean around injectors with carburetor cleaner and/or compressed air. Relieve fuel pressure. See FUEL SYSTEM in BASIC TESTING article. 2. Drain cooling system. Remove negative battery cable and air intake duct assembly. Remove throttle cables and brackets. Label and remove all electrical connectors, and vacuum hoses from throttle body assembly. Remove coolant hoses from throttle body. 3. Label and remove vacuum hoses and ground wires from intake plenum. Remove intake plenum support brackets and retaining nuts and bolts. Remove intake plenum from induction port manifold. 4. Disconnect electrical harness connectors from injectors. Using a back-up wrench on fuel rail fitting and tubing wrench on fuel pressure line, disconnect fuel pressure line from fuel rail. 5. Disconnect fuel return line at pressure regulator. Remove fuel rail bolts and spacers. Remove fuel rail with injectors and ensure injectors DO NOT fall out of fuel rail. If replacing injectors in fuel rail, replace all injector "O" rings and injector-to-rail retainer clips. INSPECTION Inspect all components for damage. Replace as required. INSTALLATION To install, reverse removal procedure. Lubricate new injector "O" rings with engine oil before installation. Use NEW "O" rings, seals and retainers in fuel rail when installing fuel inlet line and pressure regulator. Ensure intake mating surfaces are clean and smooth with no scratches. Ensure injectors are firmly seated into rail and intake port sockets. © 2007 Mitchell Repair Information Co., LLC. NOTE: DO NOT attempt to remove fuel rail inlet fitting. Fitting is staked in position in fuel rail and is NOT removable. Page 1 of 1 REMOVE/INSTALL/OVERHAUL -1990 Geo Storm 8/31/2008 http://www.ondemand5.com/mric/common/asp/printart.aspx
Posted at Sun Aug 31, 2008 7:46 am
Thanks for the information. I was afraid that you were going to tell me I would have to remove the intake phelum to get the injectors out. Guess I had better get started.
Posted at Sun Aug 31, 2008 7:50 am
Posted at Sun Aug 31, 2008 9:15 am
Yep, let us know how it goes...
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
