Car Repair Chat - Ask a Question, Get a FREE Answer.
Go Back
1990 Geo Storm loss power
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Wed Jun 04, 2008 8:39 pm |
By
aperrado,
Have Donated |
Give Feedback | Votes: 0 |
Engine Mechanical problem
1990 Geo Storm 4 cyl Two Wheel Drive Manual 170.00 miles
i found that 2 pistons of my geo are no working i checked the wires all have spark i take out the 2 spark plugs and found that they are clean what will be the possible cause of it
| Find a
car repair manual for your Geo Storm Repair Question. |
Posted at Tue Jun 10, 2008 7:51 pm |
By
aperrado,
Have Donated |
i made a compression test
the # 1 piston read 180
the # 2 piston read 180
the # 3 piston read 185
the # 4 piston read 180
| Find a
Posted at Sun Jun 15, 2008 12:39 pm |
By
aperrado,
Have Donated |
hi I got a noid light and tested the the injectors the light flashes on all injectors, I took off the air duct and found the tb dirty inside of it.
I will remove the injectors rail and clean everything
| Find a
Posted at Mon Jun 16, 2008 5:54 pm |
By
aperrado,
Have Donated |
well I pulled the spark plugs out and the 2 that work had black powder around the tip and the other two were clean with no residue.
| Find a
Posted at Fri Aug 01, 2008 9:41 pm |
By
aperrado,
Have Donated |
it took me a long time to get to fix my car. I did buy the injectors and that seems to have solved the problem. Thanks for all your help it really was usefull.
thank you for your time.
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
