Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Performance problem
1990 Ford Ranger 6 cyl Four Wheel Drive Manual 169000 miles
Starts up runs for a little bit, then dies, replaced pickup coil, not the problem, after replacing pickup coil ran for a little while, won't start at all. Could it be the coil, since it's not getting any spark at all? Please help......
Replaced the ECM, replaced distributor cap, rotor button, ignition coil, now starts up, and shuts off. Started right up as soon as ECM was replaced. Haven't replaced the little silver unit next to the coil, with one plug on it, could that be part of the problem, and if so, what is that piece called? Thank you....
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
