Car Repair Chat - Ask a Question, Get a FREE Answer.
Go Back
1990 Chevy Lumina At a loss - fuel mix too rich -
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Tue Jun 17, 2008 7:14 am |
By
teresapugh,
Have Donated |
Give Feedback | Votes: 0 |
Engine Performance problem
1990 Chevy Lumina 4 cyl Front Wheel Drive Automatic 104560 miles
I have a 1990 2 door Lumina Euro - Bought the car a couple months ago - ran sweet for the first month then the ECM died - we replaced it as well as a faulty crank shaft position sensor and a worn alternator belt - car starts now but its burning a very fuel rich mixture - to the tune of about 3 - 5 miles to the gallon!! hooked it up to a sensor and got the code for a faulty MAP sensor - went to the parts store picked one up and installed it, and the car won't turn over at all. Replaced the new MAP sensor with my original one and the car starts but with the fuel ratio issue and super rough idle - its also blowing a LOT of carbon out of the exhaust - took the MAP sensor back to the parts store and got a new one in case it was faulty but had the same issue - engine won't even turn over with the new MAP sensor in. Any ideas what to do next?
| Find a
car repair manual for your Chevy Lumina Repair Question. |
Posted at Tue Jun 17, 2008 9:45 am |
By
teresapugh,
Have Donated |
The code I'm getting is 45 - rich exhaust - will check the wires as you suggest. Thanks
| Find a
Posted at Tue Jun 17, 2008 10:14 am |
By
teresapugh,
Have Donated |
We used a noid light - every thing looks fine - got a code for MAP Sensor before we tried to change it, now the only code coming up is the rich exhaust code. Someone suggested maybe a faulty temperature sensor but we haven't got that far yet - were looking to get it back on the computer this afternoon and verify the codes and maybe try to locate the temp. sensors - according to the book there are two. Thanks again for your help  this thing is making me nutty, lol.
| Find a
Posted at Tue Jun 17, 2008 7:01 pm |
By
tbdk87,
Likes cars! |
(6) Give Feedback | Votes: 0 |
I had a similar problem on an 87 grand am. didnt burn that much gas though. Turned out to be a faulty o2 sensor. Try that as well. If the o2 sensor faults it will tell the engine to use more gas then reuired and make engine run rough. it will also still recognize a rich problem.
| Find a
Goto page 1, 2 Next
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
