Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Performance problem
1990 Chevy Lumina 6 cyl Front Wheel Drive Automatic 157000 miles
My service engine light comes on after it is warmed up. My gas mileage went down bad. I acts like it wants to die when I am at a stop light. It also acts like its cutting out. We replaced the coils and checks fluids. We are now thinking that it might be the Oxygen sensor. Please help before I go broke replacing parts.
if you dont want to go broke then get to the nearest autozone and have them scan the computer and post back the code so i can tell you what is wrong and what to replace.
autozone wont scan a 90. you'll have to jump pin a and b in the diagnostic center.
there are several posts on here that explain how to do it. then post the codes here and we'll tell you what they are...
same purpose, find your dlc connector, the upper right hand corner the two in the upright hand corners are a and b, put a clip in, turn ignition and the check light will flash out.
as dna says.
do a search on the forums here and you will find lots about it.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
