Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1978 Chevy Blazer Determ...
Auto Repair1996 Dodge Intrepid Stee...
Auto Repair2001 Acura Cl Heater Mot...
Auto Repair1986 Chevy Celebrity Fir...
Auto Repair1992 Ford Ranger Clutch ...
Auto Repair2004 Chevy Silverado
Auto Repair1991 Dodge Spirit Wipers...
Auto Repair1995 Chevy Lumina New Ra...
Auto Repair1999 Dodge Truck Water L...
Auto Repair1996 Chevy Silverado Fig...
Auto Repair2003 Subaru Baja Obd Dri...
Auto Repair1994 Dodge Caravan 1994 ...
Auto Repair2000 Cadillac Escalade I...
Auto Repair1988 Ford F250 Distribut...
Auto Repair1996 Chevy Blazer Chevy ...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Auto Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1990 Cadillac Deville Stalls and backfires
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Tue May 06, 2008 9:20 pm
By mikendiego, Have Donated
Give Feedback | Votes: 0
Engine Performance problem
1990 Cadillac Deville V8 Front Wheel Drive Automatic 108000 miles
Hi Team,
I just bought a 1990 Cadillac Deville, It has sit for about 7 months and the car requires premium fuel but the past owners were putting mid grade fuel in the car for several years.
I’m starting to get a rough idle and backfire when I press on the gas, also when I sit at a light and I also get a stall and loss of power when I press the gas pedal while driving. Sometimes it clears up and the car runs great. Do you think this is because of the gas, fuel pump, or something else?
Find a repair manual for your Cadillac Deville Repair Question.
By Advertisment,
Posted at Tue May 06, 2008 9:35 pm
By rasmataz, Certified 2CarPros Master Technician
Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744Reputation: 744 (744) Give Feedback | Votes: 66
Lets get the fuel pressure check with a fuel pressure gauge designed for your fuel system-to rule out the fuel filter, pressure regulator and fuel pump-could be bad fuel- I need the fuel pressure readings for evaluation and direction to take-
Or you can do below immediately when is stalls out to determine if its fuel or spark problem
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light.
Fuel pump/Pressure Regulator and Injector/s checks out-start checking the ignition system-power to coil, coil/s itself,distributor pick-up,control module, Cam and Crankshaft sensors.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
TYVM for using 2carpros and I'll be waiting for your return as needed-
Posted at Wed May 07, 2008 9:39 am
By Buzzsaw, Tech level 7
Reputation: 214.4Reputation: 214.4Reputation: 214.4Reputation: 214.4Reputation: 214.4Reputation: 214.4Reputation: 214.4Reputation: 214.4Reputation: 214.4Reputation: 214.4Reputation: 214.4 (214) Give Feedback | Votes: 11
Razzy codes need to be checked first, off and warmer on the heater controls with the key in the on position. look in the fuel message center for the codes, starts out 8.8.8 and ends with 0.7.0
I believe for the backfire the AIR pump and Diverter valve are bad
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
