First remove the battery cables, then remove the top bolt from the alternator it is a 12mm. After you jack up the front end, crawl under the front end on the drivers side and remove the three 14mm bolts holding the axel in place and the three 10mm bolts holding the cover for the brake lies. Rotate the axel bracket down take the oil filter and the long 12mm bottom bolt for the engine mount out. Remove the bottom bolt for the alternator remove the wire harness and positve cable, and slide it right out. Of course just put everything back it the reverse order with the new alternator when done.
