1989 Toyota Pickup alternator/ charge system/ shortage ????
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Electrical problem
1989 Toyota Pickup 4 cyl Two Wheel Drive Manual
it's not the alternator. we changed it and now it's charge is reading below the norm when started. we think it's a shortage or wire problem. the problem is what or where can we check? we checked the fuse under the hood and in under the dash. can you give me any and all info on this matter. going nuts..
If the charging voltage at alternator main mast and battery terminals are below 13.5, the alternator is bad or the beltings are loose, the crankshaft pulley is faulty.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
