Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Performance problem
1989 Toyota 4Runner 4 cyl Four Wheel Drive Manual 215000 miles
when is start my 4runner it makes a loud knocking sound from the start......i cant go over 20 mph now and it knocks louder if i try to drive it then it over heats and white smoke comes out and the water starts to boil.....the knockin sound never quits.....i took it to a mechanic and they said the crankshaft went out..can i just replace that or do i have to replace the whole engine or wat....please help me!!!
it sound as if you have a few problems to deal with, i would be having a compression test, oil pressure test and head check done, i think you will better of re building the engine if you have been running with low oil pressure as the bearing knock is destroying the engine, and the over heating and white smoke could well be a head gasket or cracked head.
This is a very hard question to answer with out viewing the engine dismantled. If you are working to a budget you may be able to pick up a re-co and have that installed rather than doing yours, this will be quicker and often cheaper as well. As for extras. do the radiator all the hoses, thermostat, have the starter checked
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
