Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Performance problem
1989 Plymouth Acclaim 4 cyl Front Wheel Drive Automatic 45500 miles
Yesterday we filled up our gas tank. Ever since we've been having a hard time starting it. It sounds like it's going to turn over, but it takes several tries to get it to start. We actually get to the point where it seems as though it's not going to start at all. Do you have any suggestions?
Did it give you the problem the first time you started it after filling the tank? If not, the gas may be the problem. Try to run it out and see if the next tank makes a difference.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
