Auto Repair Chat - Ask a Question, Get a FREE Answer.
Go Back
1989 Other Oldsmobile Models
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Mon Jun 16, 2008 5:02 pm |
By
markdionne,
Have Donated |
Give Feedback | Votes: 0 |
Engine Mechanical problem
1989 Other Oldsmobile Models 6 cyl Front Wheel Drive Automatic 204000 miles
Stopped car at a red light on hot day after driving on highway. After a few seconds, engine suddenly stalled as if it was choking. It started right up and I drove home. "Service Engine Soon" light came on and there were a few short periods of engine roughness at highway speed. Stalled a few more times at traffic lights, after about 10 seconds of idling, but started right up each time.
At home, checked the OBD code: it was 34. Checked all hoses and electrical connections. Tried running with air filter removed: still stalls. Tried again when engine was cold: problem appears to be gone but I'm afraid it will come back when engine is hot.
| Find a
car repair manual for your Oldsmobile Delta 88 Repair Question. |
Posted at Tue Jun 17, 2008 5:09 am |
By
markdionne,
Have Donated |
I looked for the MAP but I'm not sure where it is. My Chilton's shows a photo of MAP apparently mounted on the firewall, but I see nothing like it.
Car is Oldsmobile Delta 88 Royale 1989
VIN 1G3HN54C5KW341075
3.8L V6 Fuel Injected 4-door H model chassis
| Find a
Posted at Wed Jun 25, 2008 12:17 pm |
By
markdionne,
Have Donated |
I got a used MAF sensor. No change. But who knows if the used one is any good.
But in the meantime I did a little science project. I disconnected the wires from the MAF sensor. The car runs fine, even when warmed up! No stalling! (I'm getting code 34 of course.)
Who knows if the acceleration is still the same, or the gas mileage, or if the emissions are correct. But no stalling! And state emissions inspection is 16 months away...
I think what is happening is that the computer uses two inputs to decide on how much gas to inject: the throttle position and the MAF reading. When the MAF sensor is disconnected, it just uses the throttle position as a first approximation, which works better than using garbage results from a bad MAF sensor.
Next research question: what is the gas mileage with the MAF sensor disconnected? Stay tuned.
| Find a
Posted at Mon Jul 21, 2008 6:16 pm |
By
markdionne,
Have Donated |
Running with the MAF disconnected worked well for a while, but then it went back to stalling.
Got a used MAF. There was no change in the car's stalling. Using an ohm meter, I measured something like 50 megohms between each pair of pins. Same thing on both the old MAF and the replacement.
Finally I got another used MAF, and it fixed the stalling problem. This good one had much lower resistance between the pins marked + and -. About 6 K Ohms in one polarity and about 500 K Ohms with the probes reversed. The other pin had much higher resistance.
The part number on the MAF sensor was AFH50M-02A.
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
