Drive Train Axles Bearings problem
1989 Jeep Cherokee 6 cyl Four Wheel Drive Automatic 129000 miles
Hello, I am trying to figure out what is causing this loud clunking noise when i turn.
I have examined the front end myself and i found that the steering(tie rod ends)(Ball Joints) are tight, the clunking sound is accomponied by a slight movement of the wheel, as if something inside is shifting a bit, the knock is only present when the truck is holding its own weight, it does not make any noise when up on jack stands.
I am thinking it is the CV Joint on the drivers side, but im not sure, and what Parts & Tools i may need in addition to the joint itself.
any advice would be a big help.
The vehicle Vin # is 1J4FJZ8LXKL557317
Thanks in advance. Dean
