Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2006 Isuzu Trooper
Auto Repair1996 Other Nissan Models...
Auto Repair1997 Ford Crown Victoria...
Auto Repair1996 Subaru Legacy No F...
Auto Repair1999 Toyota Camry Cold ...
Auto Repair1998 Bmw 740 Leaking Seals
Auto Repair1995 Kia Sophia
Auto Repair More Repair Topics...
Site Advertising
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1989 Honda Civic Engine not firering very well
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Fri Aug 22, 2008 2:15 am
By chrisletua, Likes cars!
Give Feedback | Votes: 0
Engine Performance problem
1989 Honda Civic 4 cyl Front Wheel Drive Manual
The car developed this problem about 6weeks ago. The engine could not fire very well, i took it to my local mechanic, he change the injector nozzle and yet the problem is still on. He decided to clean and service the injector which he did but yet the problem is still their. What i observe is that the engine start normally and work well, but when you press the accelerator it will not fire properly and if you do that continuously the engine will stop. I have change the spark plug but no improvement. kindly help.
Find a car repair manual for your Honda Civic Repair Question.
Posted at Sat Aug 23, 2008 5:53 am
By KHLow2008, Moderator
Reputation: 169.1Reputation: 169.1Reputation: 169.1Reputation: 169.1Reputation: 169.1Reputation: 169.1Reputation: 169.1Reputation: 169.1 (169) Give Feedback | Votes: 13
Hi chrisletua,
Did the Malfunction Indicator Light show?
Did you test the fuel pressure ?
Are sparks strong (bluish in color)?
Posted at Sat Sep 06, 2008 5:57 pm
About the malfunction indicator light - the light did not show
For the fuel pressure - the pressure is ok
But for the spark plugs - i don't how to check that. but what i notice now is the cold starting. If that is as a result of the plug. what type do i use.
Thanks for your assistance.
from
chrisletua@yahoo.com
Posted at Sat Sep 06, 2008 9:54 pm
Hi chrisletua,
Pull a plug wire out and attach a spark plug. Crank and watch the color of the spark, should be builsh.
Posted at Mon Sep 08, 2008 11:01 am
I have check it and it is ok. can you please tell me the type of spark plug that my model use. Because, when i look at the plugs their, my local mechanics mix diffrent type.
Thanks
Posted at Tue Sep 09, 2008 4:23 am
Hi chrisletua,
Should be NGK BKR6E-11. I need to know the engine variant to be sure.
Posted at Tue Oct 07, 2008 4:42 pm
Hi Mr. KHLow2008, Moderator
Thanks so much, you always stand by me. I have search for the spark plug NGK BKR6E-11, but i cloud not find such, what i find is NKG BKR6E. the only different is the last 11.
I dont know if its the same type.
Now the car is given me a grounding sound like one bearing is bad some where. I suspect the rear Tyre side. But if i checke the ream on the tyre (the 4 tyres)no of them is hot.
secondly, the gass consumption is too much.
Please what can i do.
Thanks
Posted at Wed Oct 08, 2008 6:46 am
Hi chrisletua,
We would always have our arms opened to welcome you anytime.
NGK BKR6E would have a gap of 0.8 mm whereas the 11 = 1.1 mm. You can use the plug but they have to be regapped.
A smaller gap would cause higher fuel consumption.
Where the gas consumption is concerned, it would be hard to advise or suggest anything.
Possible causes.
1. Engine ignition timing.
2. Idle speed adjustment.
3. Driving method.
4. Brakes.
5, Clutches, might be worn and slipping causing power losses too.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
