Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manuals
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto RepairLets All Welcome Moderat...
Auto Repair2000 Chevy Tahoe My 200...
Auto Repair1993 Audi Quattro Dies ...
Auto RepairNew Grandson!
Auto Repair More Repair Topics...
Site Advertising
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1989 Ford Mustang Engine vibration
Welcome to our question and answer forum. We answer over 6,000 free and donated auto repair questions every month. All you have to do to ask a question is to signup to our forum.
Asking a question is free of charge and your question will be answered by one of our non-certified forum users for free. You can however elect to donate to make sure your question gets an guaranteed and professional answer by one of our many 2carpros certified repair technicians.
Questions with donations are answered as promptly as possible. Due to the nature of car repair problems, some take longer to solve than others. We are confident that you will be better informed regarding your problem and will have an good idea of what direction your repair needs to go after we have answered it. If you have donated and were unsatisfied with our effort we will gladly return your donation. We help thousands of people every month and want to help you too. Sometimes it requires some dialog between our technicians and you to get to the bottom of your problem. 100% of the donation is awarded to the technicians helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Mon Jul 07, 2008 7:23 am
By StevesLX, New to the forum
Give Feedback | Votes: 0
Engine Mechanical problem
1989 Ford Mustang V8 Two Wheel Drive Manual 2500 miles
I have a vibration that is comeing from my motor. I know its motor related because it does it when you are sitting still as well as when you are moving. It was originally comeing on around 3000 RPM's. I pulled my tranny out and supported the rear of the motor and tightened the motor mounts back up and started the car and reved it up to 3000 and higher and you couldn't feel it no more. I put my tranny back in and you could feel it again. So I pulled the tranny back out and I put a fresh one in that had 0 miles on it that a friend just bought and same deal you could feel the vibration with his too. This vibration is bad enough that it will vibrate the shifter so bad that it hurts your hand and arm to hold onto it. My flywheel, pressure plate and disk, pilot bearing all look fine. I just put this motor in 2 months ago after it was freshened up. It has roughly 2500 miles on it. I did find that the weight on the back of my harmonic balancer was lose. I tightened it back down and started the car up and the vibration was gone at 3000 RPM's, but now its at 5000 RPM's. Not sure if its something inside the motor or not but I need some advise here before I start to tear my motor apart. I have thought about a miss from a burnt plug or something but when you rev the car it doesn't act like it has a miss. This whole deal started all at once it didn't gradually come on. Last Monday the car was fine and Tuesday morning when I started it, it was doing this dumb stuff.
Find a car repair manual for your Ford Mustang Repair Question.
By Advertisment,
Posted at Mon Jul 07, 2008 7:53 am
By Docfixit, Tech level 7
Reputation: 85.3Reputation: 85.3Reputation: 85.3Reputation: 85.3 (85) Give Feedback | Votes: 3
Check crankshaft end play you may have an issue with thrust bearing.
Posted at Mon Jul 07, 2008 8:09 am
Exactly what do I need to do to check the crankshaft end play? Can Ido that with the motor in the car?
Posted at Mon Jul 07, 2008 1:29 pm
You can it might be a little tricky. You will need a dial gague and a magnet base attach to block rig so the gague pointer is on the crankshaft bolt. First push back the crank pully wedge a 2x4 between sway bar and pully. Then set dial gague get between timming cover and harmonic and pry forward gague should move .003 to .005 any more thrust bearing is severly worn out has spun out of position. Lets crank move forward to far on accel binding the rods ie. vibration
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
