Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1995 Chevy Cheyenne Spe...
Auto Repair2000 Volkswagen Beetle Oil
Auto Repair2004 Dodge Neon Battery...
Auto Repair2000 Vauxhall Vectra Li...
Auto Repair2005 Toyota Avalon Wind...
Auto Repair1998 Chevy Lumina Rear ...
Auto Repair1997 Other Volkswagen Mo...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1989 Ford F350 Can't get hard pedal on brakes
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Tue Sep 09, 2008 2:06 pm
By gvranches, Likes cars!
Give Feedback | Votes: 0
Brakes problem
1989 Ford F350 V8 Four Wheel Drive Manual 88000 miles
I can't get the brakes to bleed properly. I've replaced the brake booster, master cylinder (new-not rebuilt), vacuum pump(it's a 7.3 diesal), both rear wheell seals, several sections of tubing (due to rust) and a rubber hydraulic hose at one front wheel. The proportioning valve is bypassed by manual gizzmo that controls the amount of fluid going to the rear brakes.
I tried to isolate the front from the rears by plugging the rear oriface at the master brake cyl. This produced a harder pedal but I still couldn't get the wheels to lock up.
I had the vacuum pump and rear wheel cylyinders & bypass gizzmo intalled by two different shops. I'm stumped. Any suggestions will greatly be appreciated. You might want to know this vehicle came from the north and is very rusty. It has low mileage and steers good but sat up a good part of the time because it was used as a snow plow (4WD)
Thanks!
George V
I
Find a car repair manual for your Ford F350 Repair Question.
Posted at Tue Sep 09, 2008 4:12 pm
By blackop555, Certified 2CarPros Master Technician
Reputation: 102.8Reputation: 102.8Reputation: 102.8Reputation: 102.8Reputation: 102.8 (103) Give Feedback | Votes: 27
what seems to be the problem?
do you have any breaking?
incredible low pedal?
pressure build up with engine off?
Posted at Tue Sep 09, 2008 5:15 pm
I have some brakes but unsafe to run on the road.
Brakes go clear to floor. when bleeding, air blasts out right rear (longest line); after a few procedures, it runs clear. Did all four four wheels in proper sequence and even bleed the master cyl by loosening connections. Pressure seems less with engine running.
I'm totaly baffled. Could it be sucking air somewhere ? I checked the entire system for leaks.
Posted at Fri Sep 12, 2008 2:22 pm
do they keep getting more air in the lines? imeditely after bleading is done? or is fluid coming out with no air, just no pedal?
Posted at Fri Sep 12, 2008 6:28 pm
Yes, air seems to be creeping back especially the right rear (the longest line). I would bleed them 4-5 times til finally no air, then go around to the remaining 3 wheels only to go back again to the right rear and find air again. I would have my buddy stand on the pedal, trying to bust out a line if he could to find the possibilty of a small leak somewhere--no find.
Another bit of info--I mentioned earlier the proportioning valve was by-passed with a manual valve. This was done at a brake shop, but the tech did not disconnect the wires going to the proportioning valve. I was hopoeful after disconnecting the wire would solve my problem but didnot.
I also saw on a Ford forum website where someone described my problem to a t, saying it was solved by "cross bleeding" but didnot describe how that was done. Another individual said the hydraulic hose at the fron wheel from frame to claipier deteriotes somehow to form an internal flapper vlave. He said after changing the hose, it solved the problem. I changed one hose but didn't change the passenger side yet. I appreciate any suggestions you might have. Thanks!
Posted at Sat Sep 13, 2008 4:35 pm
what i would suggest doing would be quite simply to bench bleed the master cylinder and reinstall, then bleed out the metering/combo valve them go to rear right and work in sequience bleeding each one and seeing how it works.
the flapper valve deteriated hose problem usually will let fluid in but wont let fluid back through it and will usually cause a dragging problem NOT a air geting in line problem.
reember just because no fluid is leaking on a caliper doesnt mean it cant suck air back in.
Posted at Sat Sep 13, 2008 4:36 pm
try gavity bleeding also, just crack all bleeders and let her sit for 1 hour.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
