Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Manual Ask a Car Repair Question
Auto Repair Manual Car Questions by Manufacturer
Auto Repair Talk Auto Questions by Topic
Vehicle Repair Car Repair Forum
Auto Repair Talk Car Repair Troubleshooting
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Video Series
Vehicle Repair How to Use Test Equipment
Auto Repair Manual Car Maintenance Information
Vehicle Repair Service Engine Soon Light
Vehicle Repair Car Parts and Equipment Store
Vehicle Repair How Does it Work?
Vehicle Repair Safety Inspection
Auto Repair Manual Online Car Repair Manual
Vehicle Repair Smog Test Preparation
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1998 Chevy Truck Oil Pr...
Auto Repair2004 Ford F150 Truck St...
Auto Repair2001 Ford Ranger Won't ...
Auto Repair1996 Chevy Beretta Dead...
Auto Repair2004 Saturn Vue Loss Of...
Auto Repair1989 Nissan Truck Truck...
Auto Repair1992 Honda Accord
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Auto Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1989 Dodge Caravan
Welcome to our question and answer forum where over 6,000 free auto repair questions are answered every month, after you have completed our free signup you will able to ask a question and receive an answer from one of our many forum members.
If you elect to donate any small amount of money we will assign one of our 2CarPros Certified Repair Technicians to answer your question. Questions with donations are answered promptly and 100% of the donation is awarded to the technician helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Sat Jul 26, 2008 5:03 pm
By hugocesarjr, Have Donated
Give Feedback | Votes: 0
Steering problem
1989 Dodge Caravan 6 cyl
how do i disconect the rack and pinion from the steering shaft their a u joint what tools do i use?
Find diagnostic tools, replacement parts or locate a car repair manual for your Dodge Caravan Repair Question.
By Advertisment,
Posted at Sat Jul 26, 2008 7:01 pm
By BMRFIXIT, Tech level 10
Reputation: 416.1Reputation: 416.1Reputation: 416.1Reputation: 416.1Reputation: 416.1Reputation: 416.1Reputation: 416.1Reputation: 416.1Reputation: 416.1Reputation: 416.1Reputation: 416.1Reputation: 416.1Reputation: 416.1Reputation: 416.1Reputation: 416.1Reputation: 416.1Reputation: 416.1Reputation: 416.1Reputation: 416.1Reputation: 416.1Reputation: 416.1 (416) Give Feedback | Votes: 15
rack and pinion removal and installation
let me know if more is needed
good luck
Removal
1.Disconnect hoses from steering gear (if equipped). Raise and support vehicle. Remove front wheels. Separate tie rod ends from steering knuckles. Disconnect engine damper strut from crossmember (if equipped). 2.Support front suspension crossmember with floor jack. Remove front suspension crossmember bolts. Lower front suspension crossmember so steering gear can be disconnected from steering column. 3.Remove steering gear retaining bolts. Remove steering gear. The steering column coupling will disconnect from the steering column.
Installation
1.To install, reverse removal procedure. On manual steering gears, ensure serrations are aligned. During installation, an assistant will be needed to align steering column coupling with steering column. 2.Install all crossmember bolts. Tighten RIGHT REAR crossmember bolt first. Install remaining components and fill steering gear. Adjust toe-in. See WHEEL ALIGNMENT SPECIFICATIONS & PROCEDURES article in WHEEL ALIGNMENT section.
CAUTION:Tighten RIGHT REAR crossmember bolt to specification prior to tightening remaining crossmember bolts. ALL crossmember bolts MUST be tightened to 90 ft. lbs. (122 N.m).
© 2007 Mitchell Repair Information Co., LLC.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
