Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Suspension problem
1989 Chevy Truck V8 Four Wheel Drive Automatic 125000 miles
I have a one ton chevy dually 4x4 with a straight axle. The problem I am have is when I am driving and go over for example railroad tracks or a small pot hole the front of the truck shakes to where I have to come to almost to a stop to stop the shaking. I can not find anything wrong with the front suspension. Nothing is loose . The tierod end are new and the leaf spring bushings are new. The tires are new and balanced. The upper and lower ball joints have no play in them. My question is can the ball joints cause this kind of shaking ? Or can it be something else causing this problem.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
