Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1989 Chevy Suburban Can not stay on, or will not start
Posted at Thu Nov 19, 2009 1:14 pm |
By
enricobr,
Likes to hang around! |
Give Feedback | Votes: 0 |
Engine Mechanical problem
1989 Chevy Suburban V8 Four Wheel Drive Automatic 150,00 miles
Ok, my 1989 Chevy Sub, 5.7 liter, 4wd will not start. The truck has been sitting for 3 years - with out being started. It had a 1/2 tank of gas sitting in it for those years.
I changed the oil and filter, the PVC valve, the fuel filter, air filter, battery and added 24 ounces of dry gas for the 20 gallons of gas in the tank. I also cleaned the carb with carberator cleaner and added about another 5 gallons of fresh gas. The truck will only start if I pour gas or spray carb cleaner in the carberator, it will stay on for 3 or 4 seconds, and then die. In that time, if i press the gas peda,l it will rev as much as I press. Right before it dies, the check engine light comes on. What should I try? |
Find a
car repair manual for your Chevy Suburban Repair Question.
Posted at Thu Nov 19, 2009 1:24 pm |
By
jdl123,
Moderator |
     (3061) Give Feedback | Votes: 92 |
welcome to the forum, use a gage and check fuel pressure, TBI around 10 psi. Can you see the injectors spray gas, engine cranking. Even if the injectors are spraying, 5 psi, will not start a v8 engine, in my opinion. If you crank it long enough and the injectors are spraying, you might finally get enough gas to start,but, it will run poorly and die quickly. Any codes? |
Find a
Posted at Thu Nov 19, 2009 1:32 pm |
By
enricobr,
Thank you very much for your reponse. Where would I hook up the gage? The engine cranks and for the 4 seconds its on, it sounds great. |
Find a
Posted at Thu Nov 19, 2009 2:04 pm |
By
jdl123,
Moderator |
It's easiest for me at the fuel filter. Not enough room in the engine compartment for a old man to climb up in there, stay squatted down, tying into the supply line at the throttle-body. Last time i tried that, I have to remove the coil and bracket to get enough room to back out the supply line. |
Find a
Posted at Thu Nov 19, 2009 5:28 pm |
By
enricobr,
Ok, I looked at the carberator and saw no gas coming out of the injectors while tring to start it. Thank you for your help, I really appreciate it. |
Find a
Posted at Fri Nov 20, 2009 6:54 am |
By
enricobr,
I checked the injectors and saw no gas spraying out, I am going to disconnect the fuel filter and see if gas shoots out, to try and rule out the fuel pump. Any suggestions as to what else i could try to clean out the entire fuel system?
thanks |
Find a
Posted at Fri Nov 20, 2009 7:45 am |
By
jdl123,
Moderator |
Use a noid lite on injector electrical connector, see if there is a pulse, engine cranking. Basically, check for B+ and ground at the injector. |
Find a
Posted at Sat Nov 21, 2009 7:07 am |
By
enricobr,
Thank you for your reply. I have fixed the problem, and I will share with you what I did. I took a very basic approach. First - I looked at the injectors and noticed no spray while cranking. Then, I disconnected the fuel filter and noticed no flow of gas coming out of the fuel line while cranking. Then, I checked all the fuses, they were OK, I also checked for power at the fuel pump, and there was power. So now, I pumped some air into the fuel line, using a bike pump, to rule out a clogged fuel line, and I could hear gas bubble in the tank. I then tried to start it again, with no luck. Finally, I dropped the tank, disassembled the fuel pump assembly, and replaced the pump, O-rings and gasket only. I put it all back together again, and it was a great success! Thank you for all your input! |
Find a
Posted at Sat Nov 21, 2009 8:10 am |
By
jdl123,
Moderator |
Glad you got it going your way. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
