Electrical problem
1989 Chevy Silverado V8 Two Wheel Drive Automatic 106000 miles
How do you reach the solenoid wires to take meter reading or if necessary to remove them before removing the starter unit? this is a 1989 5L Silverado. I can easily get to the two main bolts that secure starter to bell housing, but from under the truck I can not see the solenoid let along reach it. Can solenoid be reached from wheel well if small flexible cover is removed or do I have to remove the inside metal wheel/fender unit (WOW)? Installed a new battery, but when ignition key is turned to start, I do not hear anything and assume problem is solenoid. NO dimming of lights when key is turned to start.
