Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1995 Chevy Cheyenne Spe...
Auto Repair2000 Volkswagen Beetle Oil
Auto Repair2004 Dodge Neon Battery...
Auto Repair2000 Vauxhall Vectra Li...
Auto Repair2005 Toyota Avalon Wind...
Auto Repair1998 Chevy Lumina Rear ...
Auto Repair1997 Other Volkswagen Mo...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1989 Chevy Astro won't stay running
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Fri Jun 27, 2008 7:46 am
By tattoz1, Likes cars!
Give Feedback | Votes: 0
1989 Chevy Astro 6 cyl Two Wheel Drive Automatic 160000 miles
hi yesterday i was driving around and everything was ok then saw i was out of gas so i got 25.00 and drove 1 mile home,2 hours later i went to start the van and won't stay running with out really pumping the gas it runs for about 3 to 4 sec. then dies i remoned the air cleaner and see gas spaying from the injectors. this van is not that great of shape and was free but it is my only transportation i need for work and to get my mother around.the van does run pretty good and smooth until now please HELP!!!!!
thanks
rick ps i just changed the fuel filter and i get the same thing i don't have the tools to check the pressure
Find a car repair manual for your Chevy Astro Repair Question.
Posted at Fri Jun 27, 2008 9:11 am
By jdl123, Tech level 4
Reputation: 20.1 (20) Give Feedback | Votes: 0
How long has it been since you replaced the fuel filter? I have seen injector spray patterns, on TBI systems, that looked good, but the fuel pressure was half of what is should have been.
The longer you crank it, the more gas it sprays in the engine, once there's enough gas, it'll probably start, but, it will run poorly and die quickly.
If the fuel filter has any miles on it, change it, if that doesn't help, then check fuel pressure.
Are there any codes?
Posted at Fri Jun 27, 2008 10:05 am
i just changed the fuel filter and the same thing i don't have the tools to check the pressure thank for your fast responce that was great
Posted at Sat Jun 28, 2008 6:50 am
Some of the nationalbrand autostores will loan tools. You might see if they have a fuel pressure gage that they might loan-out. You might have to put up a deposit, but, you get the money back when you return the gage. It needs to be for a tbi system.
Can you check for codes?
Posted at Sat Jun 28, 2008 8:14 am
jdl123 you've been a great help i will check the auto store and see if they have the gauge can you tell me where i plug it in i do know somewhat how to work on cars as long as there before 1970 you know 3 wires and some gas and off you go.so very much thanks for the help and i will donate as soon as i get paid wed.
rick
Posted at Sat Jun 28, 2008 11:36 am
My information is free, no donation required. I'm sure the people that run this site would appreciate it.
On a post where a donation has been made, I don't answer those. Those people want somebody with 20 stars by their name, to answer their question, any less stars and they are disappointed.
A TBI system doesn't have a schrader valve, so you have to tee into the supply line. On some trucks, it's easier for me to tee-in at the fuel filter, even if I have to crawl under the truck. If it's easier at the throttle-body under the hood, do it there.
Just incase it might be an issue other than fuel, check for codes. With the 12 pin data link connector, top row, the two pins at the right hand side, use a jumper wire between those pins, turn the key on, no crank, just turn the key till the dash lites come on, the check engine lite should start flashing, you count the flashes to get the codes. As an example, the code 12 would be 1 flash, a slight pause, then 2 quick flashes. There is information all over the web about accessing codes.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
