Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
1989 BMW 750Li V12 Automatic 150,00 miles
i parked car for 6 months was running fine came now to drive wont start dash first said oil temp sensor see owners manual now when turn over says that and oil pressure sensor will these not make run wants to fire off but cant
The oil pressure switch can not keep it from starting. Neither will the oil level sender. Is there oil in it? Is there fuel in it? And is it good fuel and is it being injected into the engine? Is there spark? That power train can be diagnosed with the BMW proprietary software and the faults (if any) read out, but lets start with the basics, check for spark and fuel and let us know what you find.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
