Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1989 Acura Integra 4 cyl Two Wheel Drive Manual
Ok Heres the problem.
All was fine, car was bought used. started well (cranked over). Took a trip to local store. got out and car would not crank there after. able to push start and run fine. Reemoved starter and had it checked (all diags. on starter passed). Battery holds charge fine, All lights and Etc. work.
Check for 12 volts at the small wire on the starter with key in crank position. If it has it the starter is bad, if not check for power in and out of the clutch switch, mounted on the pedal assembly under the dash. Should have power in and out with clutch pushed in, if not switch is either bad or out of adjustment
Should never bypass this, then it can start in gear.remove a/c duct, should pull out of the way. One of the wires will have power with key in crank position, the other will power up when clutch is depressed, looks like both wires are black/white
Thank you so much. The problem has been solved without me paying a mechanic BIG BUCK. It just turned out that a screw fell out which pressed the swith when the clutch pedal was pressed. Simplre fix with your guidence.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
