Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2002 Dodge Dakota
Auto Repair1976 Chevy Truck No Power
Auto Repair1998 Subaru Legacy Fron...
Auto Repair1998 Ford Explorer Comp...
Auto Repair1999 Nissan Altima Acc....
Auto Repair1993 Ford F150 No Oil P...
Auto Repair1997 Ford Escort Fan Re...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1988 Toyota Supra engine cranks but wont start
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Wed Nov 19, 2008 9:46 am
By Jackle, Likes cars!
Give Feedback | Votes: 0
Engine Mechanical problem
1988 Toyota Supra 6 cyl Two Wheel Drive Automatic 188000 miles
Last night it was a bit cold, I went to my work at 4 and was supposed to leave at 1:00 am. I went up to the car and tried to start it but it just cranks but wont start. I tried to jump start the car with friends car battery cable but it didnt help. Wat is the problem so i can take it to fix it.
Find a car repair manual for your Toyota Supra Repair Question.
Posted at Wed Nov 19, 2008 10:08 am
By pear69, Moderator
Reputation: 60Reputation: 60Reputation: 60 (60) Give Feedback | Votes: 3
I am assuming that the reason you jumped the car is because you killed the battery from cranking the engine too long...If the engine cranked just a little before you had to jump it then test the battery and clean up the battery connections - if it's ok then test the alternator.
In order to find the problem you must determine if it first- is getting fuel, and second- getting spark.
I assume that this the first time this has happened, so this problem is a sudden failure -- right? Fuel pumps and ignition modules fail like this -- but it must be tested and confirmed first.
Make sure the car is securely in park -- the neutral safety switch will act like this also.
Posted at Wed Nov 19, 2008 6:12 pm
I called some little knowledge guys to look at it and mostly I heard from them was the fuel pump is gone. I am taking it to the toyota dealer tomorrow, they told me that they have to look at it first and then only they will tell me that if they can fix it or not. Would it be good to take it to the dealer or call a mechanic. I have to go to another city coming month so I dont want my car to act like that.
Posted at Wed Nov 19, 2008 11:06 pm
A dealer is the best place to have a car repaired as long as the dealer has certified mechanics - and most do. However, a dealer is not cheap, but paying a little more may be worth it in the long run. A dealer has access to a massive data base related to your specific car - as it relates to problems - upgrades - and common failures. 188000 miles is well beyond the life expectancy of a fuel pump for your car so it very well may be the problem, but testing it is the key to solving your problem - a dealer has that capability BEFORE they replace a part - a mechanic usually does not. A dealer also uses factory parts, not aftermarket, which sometimes is important.
A fuel pump failure is not a hard thing for any mechanic to diagnosis. It will be cheaper to take your car to a mechanic, but if it is not a fuel pump then it is unlikely a mechanic will be able to diagnosis the problem as fast as a dealer.
BTW dealer mechanics are mechanics too. They are just more specialized in one make of car - in your case it is a Toyota.
Keep me posted and good luck
Posted at Fri Nov 21, 2008 10:51 pm
I took it to the toyota dealer, after 1 day I called them and they told me that the ignition coil is bad. Wat do u think of that, it may be true or not. They asked for upto 600 dollars to fix it, I am searching in the internet to get some cheap one. How do i fix it if I get a cheap one in the internet.
Posted at Sat Nov 22, 2008 9:13 am
A bad ignition coil will cause your problem. The part itself is $70 at autozone. A factory toyota part is probably double that.
Changing a coil is usually not a big deal and is usually not hard- Depending on its' location. Follow the spark plug wires back to the distributer cap - there will be a coil wire connected in the middle of the distributer cap -- this wire will go to the coil. Observe the coil and look at things like -- what tool you need -- what you may need to remove to access the coil etc. Be sure to disconnect the positive battery cable when doing this job. I do suggest investing in a repair manual like haynes, for your car. They are cheap and you will be suprised on how many repairs you can do yourself referencing these repair manuals.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Models
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
