Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Suspension problem
1988 Pontiac 6000 4 cyl Front Wheel Drive Automatic 223000 miles
i hads my front struts replaced and strut mounts . the one on the left makes a ticking sound when you go over bumps and the right one is stiff turning as if it was old and seizing up .these parts are only 6 monthes old . the mount on the right was replaced agian thinking it was defective and still no change. all parts are monroe
Hi:
The ticking could be a cracked spring. Check it where it mounts on the bottom. Also, I'm not sure that the strut would cause a turning problem unless it's really bad. Are you sure the rack and pinion is good. The 80's was a bad time for GM Racks. They would stick / grab due to a bushing problem.
Let me know what you think or if you have any other questions.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
